Il y a en tout 2 utilisateurs en ligne :: 0 Enregistré, 0 Invisible et 2 Invités :: 1 Moteur de recherche
Nous avons 93 membres enregistrés
L'utilisateur enregistré le plus récent est Run&Rock
Nos membres ont posté un total de 4499 messages dans 859 sujets
Dominez la route...
Dominez la route...
Message  Misterfax le 09.02.17 15:29
Tel est le slogan d'Harley pour la sortie de la Road King Special 2017 !
Belle, non ?
DIMENSIONS .. en anglais !!
Length – 95.4 in. (2423 mm)
Overall Width –  38.7 in. (983 mm)
Overall Height – 45.1 in. (1146 mm)
Seat Height:
• Laden 26.4 in. (671 mm)
• Unladen 27.4 in. (695 mm)
Ground Clearance – 4.9 in. (124 mm)
Rake (steering head) – 26°
Fork Angle – 29.25°
Trail – 6.9 in. (175 mm)
Wheelbase – 64 in. (1625 mm)
Tires (Dunlop Harley-Davidson Series, bias blackwall front and rear):
• Front – D408F BW 130/60B19 61H
• Rear – D407 BW 180/55B18 80H
Fuel Capacity – 6 gal. (22.7 L) (warning light at approximately 1.0 gal.)
Oil Capacity (w/filter) – 5.2 qt. (4.9 L)
Transmission Capacity – 1 qt. (.95 L)
Primary – Chain
Case Capacity – 1.1 qt. (1.0 L)
WEIGHT:
• As Shipped – 781 lb. (354 kg)
• In Running Order – 818 lb. (371 kg)
• Gross Vehicle Weight Rating – 1360 lb. (617 kg)
• Gross Axle Weight Rating
• Front – 500 lb. (227 kg)
• Rear – 927 lb. (420 kg)
Luggage Capacity
• Volume – 2.5 cu. ft. (0.07 m3)
ENGINE
Engine – Milwaukee-Eight 107 Engine
Valves – Pushrod-operated, overhead valves with hydraulic, self-adjusting lifters; four valves per cylinder
Bore x Stroke – 3.937 in. x 4.375 in. (100 mm x 111.1 mm)
Displacement – 107 cu. in. (1746 cc)
Compression Ratio – 10.0:1
Fuel System – Electronic Sequential Port Fuel Injection (ESPFI)
Air Cleaner – Paper, washable
Exhaust – Black, 2-1-2 exhaust withtapered mufflers
Lubrication System – Pressurized, dry-sump with oil cooler
DRIVETRAIN
Primary Drive Chain, 34/46 ratio
Final Drive Belt, 32/68 ratio
Clutch Hydraulically actuated 9 plate wet, Assist & Slip
CHASSIS
Frame – Mild steel; tubular frame; two-piece stamped and welded backbone; cast and forged junctions; twin downtubes; bolt-on rear frame with forged fender supports; MIG welded Swingarm Mild steel; two-piece drawn and welded section; forged junctions; MIG welded
Front Fork – 49 mm Dual Bending Valve
Rear Shocks – Premium low height hand-adjustable rear suspension
Wheels: Black, Turbine Cast Aluminum
• Front – 19 in. x 3.5 in. (483 mm x 89 mm)
• Rear – 18 in. x 5 in. (457 mm x 127 mm)
Brakes:
• Caliper Type – 32 mm, 4-piston fixed front and rear
• Rotor Type – Dual floating rotors (front), fixed rotor (rear)
(diameter x width):
• Front – (dual) 11.81 in. x .2 in. (300 mm x 5.1 mm)
• Rear – 11.81 in. x .28 in. (300 mm x 7.1 mm)
• Anti-lock Braking System Standard
Suspension Travel:
• Front Wheel – 4.6 in. (117 mm)
• Rear Wheel – 2.15 in. (54.6 mm)
PERFORMANCE
Engine Torque: North America 111.4 ft. lb. @ 3250 RPM (151 Nm @ 3250 RPM)
Lean Angle:
• Right 32°
• Left 31°
Fuel Economy (Combined City/Hwy) – 45 mpg (5.2 L/100 km)
ELECTRIC
• Headlamp Dual halogen headlight 55-watt 625 lumen low beam, 65-watt 1570 lumen high beam
• Tail/Stop Lights 8W/28W
• Front Signal Lights 8W/28W
• Indicator Lamps High beam, running lights, directional light bar, neutral, low oil pressure, engine diagnostics, turn signals, battery, security system (optional), low fuel warning, cruise control, ABS, Gear/RPM display, miles to empty display
http://www.harley-davidson.com/fr_FR/Motorcycles/road-king-special.html
Re: Dominez la route...
Message  Misterfax le 09.02.17 15:35
